B Body Rear End
Started by Darkman, June 29, 2010, 01:41:11 AM
Darkman
Hi guys,
I have a few questions I would like to find out the answers to:
1) What rear end comes with a standard 318 with a 904 transmission? Is it a 8.25" diff?
2) Can the internals (ie axels and diff centre - or pumpkin as you guys call it) of a 8.75" go into a 8.25 diff/axel housing (in other words are the housings the same and just the internals different)
Your help is greatly appreciated!
Make it idiot proof, and somebody will make a better idiot!
If you think Education is difficult, try being stupid!
resq302
I know for E body cars, if you got a 318 you would have gotten the 8 1/4 but could have also gotten an 8 3/4 rear.  B-bodys, I am not 100% sure.  As for parts interchange between the 8 1/4 and 8 3/4, I do not think that anything can be interchanged as the 8 3/4 used a third member the bolted in from the front of the housing vs. the 8 1/4 that had a differential cover on the rear.
Brian
Depends on the year, the 8 1/4" didn't arrive until '69.
Nothing interchanges between an 8 1/4" and an 8 3/4", the 8 3/4" is a drop-out...the 8 1/4" isn't..
Darkman
So a 1968 Charger 318 car with a 904 trans would have a 8 3/4 rear? That would be handy to know for sure...I don't have any fender tag info...
adauto
Never too many! 70 Chally R/T Convert-70 GTX-68-69-74 Charger-68 Dart GTS
http://a-dauto.com/  http://www.facebook.com/pages/A-D-Truck-and-Auto-Parts/67427352555?ref=hl
Daytona R/T SE
8 3/4 in my '68 318/auto.  :icon_smile_big:
NMike
8 3/4 in my early 69 318
no318
I have also seen 318 cars with 8 3/4 rears, too.  I don't know if you can tell off of the fender tag or not.
All of my 68 Chargers (including 2 318 auto cars) have/had an 8 3/4" rear - except the 4-speed R/t which has a Dana.
TylerCharger69
8 3/4 '68 rear end will be a "742" case   as a '69 case would be a "489" case
In a 318 car I would expect to see a 741 case.
Rolling_Thunder
I believe all B-bodies had an 8 3/4 diff in 68 and 69...          in 1970 they started using the 8 1/4  i believe for the 318 cars
Darkman
Thanks for all your input guys, but luckily for me this question is no longer as I will not be going down this path with a 318
