guess the bellhousing game!
Started by RD, June 14, 2010, 09:47:06 PM
RD
elacruze
1968 505" EFI 4-speed
RD
Rolling_Thunder
Oldsmobile as well I believe use that same bellhousing
elacruze
Quote from: Rolling_Thunder on June 14, 2010, 10:26:03 PM
Yup, B-O-P but I forgot that Olds made stick shifts.  :slap:
68r/t
That is  a Ford  bellhousing, most probally to suit a T5 Trans with a cable operated clutch.
Starter bolts to the bellhousing on Fords.
elacruze
Quote from: 68r/t on June 15, 2010, 06:55:20 AM
By yimminy, you're right. GM doesn't go full circle at the engine, either. Oops.  :pushup:
