Anybody know about REDBORE master cylinders?
Started by RECHRGD, October 02, 2009, 09:57:19 AM
werner
NEVER CHANGED MINE. DIDNT EVEN BOTHER TO CHECK TO BE HONEST WITH YOU. MAYBE SOMTHING I SHOULD LOOK INTO ?
1969 dodeg charger, 528 hemi ,Tko 5spd.
werner
WHERE WAS THE INFO ON PORTS BEING DIFFERENT ?
RECHRGD
The original drum brake MC shows a R at the front port and a F at the rear port.  The master that came with the front disc kit did not say anything but the larger fluid compartment was at the rear, as it should be for the front discs.  It never crossed my mind when the RedBore MC came with the larger compartment in the front and I just plumbed it up as before.  The RedBore instructions also shows port "A" (front) as going to the front brakes.  But, who needs instructions anyway.  Right?   Bob
13.53 @ 105.32
werner
PROBLIBLY NO DIFFERENCE ON MY CAR THEN SINCE I HAVE 4 WAY DRUMS. wHEN I PUT DISCS ON FRONT i WILL HAVE TO CHANGE PORTS.
THANKS
