Is there any tricks to priming the car with fuel? (mech pump)
Started by Chargeraddict, July 08, 2009, 12:51:35 PM
Chargeraddict
 Hi guys, I just put a couple gallons of fuel in the car for the first time (not sure if thats enough fuel to draw into the sender )  Anyways Im cranking and cranking but no fuel is getting to the carb?
Rolling_Thunder
generally the starter does not turn the engine enough for the mechanical pump to suck fuel...     get some more fuel and fill the carb bowls
Chargeraddict
Belgium R/T -68
Neal_J
A can of ether (starting fluid) has always worked for me.
Harbor Freight sells a big ol sucker thing for 4.00, it's the size of a grease gun, one pull and you got gas all the way to the carb. Hook the line up to the carb and use some in the sucker to shoot in the throat and your good to go! It worked for me A OK! It's also good for pulling lube out of the axle.  :2thumbs:
BigBlockSam
just spray some carb cleaner in the carb  .acts like starter fluid but not as rough on the motor.  :cheers:
Quote from: Rolling_Thunder on July 08, 2009, 01:34:30 PM
This is my preferred method for a dry fuel system startup using a mechanical pump. Just fill the bowls through the vent tubes and once the engine fires it will run and prime the fuel lines. Very easy....so easy a Caveman can do it.  :lol:
Stretch
No.1! Ether is for diesels! Not gas engines!
Running on carb clean is not wise either!
Get an empty 16oz plastic pop or water bottle and drill a 1/6-inch hole in the cap. Remove the blue plastic seal from the inside of the cap. Pour some gas into the bottle. You now have a way to squirt some gas into the carb with lots of control. You can keep it running like this without washing town the cylinders until gas gets there on its own.
:icon_smile_cool:
I may be schizophrenic but at least I have us!
TylerCharger69
I never realized that priming a carburetor was such a scientific endeavor.   :shruggy:
AnCieNt1
i use a old twist top mustard bottle to fill my carb bowls
BigBlackDodge
Quote from: firefighter3931 on July 08, 2009, 09:31:08 PM
BBD ;D
BigBlockSam
QuoteRunning on carb clean is not wise either!
i've used this method for a long ,long time.started many engines that way .never an issue . just short bursts of spray. there are more then
  one way to skin a cat .  :lol:
