WHat does this term mean?
Started by BIRD67, June 25, 2009, 12:36:49 PM
BIRD67
In reference to car magazines, I am always hearing the term "reverse manual valvebody" when talking about automatic transmissions..What exactly does it mean? I think I have a general idea but I'm not sure.. Any help would be appreciated.
I will not make any deals with you. I've resigned. I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered. My life is my own. I resign. -Number 6, The Prisoner
R.I.P. Matthew Fraser 4/30/10
lisiecki1
a reverse manual valve body has a shift pattern of park, reverse, neutral, 1, 2, 3, instead of the standard park, reverse, neutral, 3, 2, 1, the term "manual" means that you have to manually shift each gear, up and down, the transmission WILL NOT upshift or downshift on it's own.
:iagree:
I run one in my Charger & I love it :drive:
LeadfootBob
The big advantage, in my opinion, is that you can do away with the kickdown linkage and run the slushbox at constant full line pressure. Hard shifting is an understatement. My '74 monte carlo has a powerglide with race prep and manual VB, makes me cringe whenever I upshift, especially at throttle :-)
Proud member of the jack stand racing team since 1999.
'70 Charger 500: "Bronson", some kind of hillbilly hot rod in progress.
'89 Chevy Caprice 9C1: "it's got a cop motor..."
The downside, depending on your point of view, is that it is no longer an automatic transmission.  You must do all upshifting and downshifting on your own and some will see that as a PITA on a street car.
