Help??? Wheel question...
Started by wordslikebullets, August 22, 2008, 07:40:41 PM
wordslikebullets
Does any one know if any of the new factory wheels on the Magnum or New chargers would fit a 1973-74 Charger?  I know with a little work one can make any wheel work but I kind of like the Magnum 17" wheels and if they fit then I would get some.  I know that the bolt patern is the same (5x4.5) but Im not sure about the back spacing.  Any help would be great.  Or if you know of a factory dodge wheel that would fit let me know.
Ben
I Love Chargers Yes I Do....I love Charger How Bout You
KMPX2
No the bolt patern is not the same !!! It is close. New wheels are 100mm 4.5 comes out to 117mm. Some guys will tell you that they fit. But if you do get them on the studs are not centered in the holes & this makes the lugnuts tighten down wrong. Very unsafe at best.
