front sway-bar
Started by My68Charger, July 08, 2008, 08:06:16 PM
My68Charger
I just got my new front sway-bar bushings for my 68, and after looking at the mounts they are welded, any ideas on how to get the old ones out with out cutting the mounts? I took it down to a local shop and they wanted to cut the mounts and then re-weld them back together... Something tells me that not the right way to get it done... I will any and all ideas.
Chatt69chgr
Actually, cutting and rewelding is the way to do it.  I have read that you can get these in without doing that but it's supposed to be very difficult.  I would think that a welding process that introduced the least amount of heat would be the best.  Not sure if this would be Mig or Tig.
http://www.69hemi.com/mechanical.html
Check above website.
Getting those original rubber bushings out is one of the very few times on my Charger where I just gave up & destroyed something in order to get it apart.
Shakey
Quote from: Chatt69chgr on July 08, 2008, 11:43:53 PM
I followed Jet's instructions and did it this way.  Turned out fine.
