FENDER TAG ?
Started by Steve P., July 16, 2008, 04:12:50 PM
Steve P.
Today I was going through some junk in a drawer and found a copy of a TEXAS title and a fender tag wrapped up in it. I DO have a pretty lousy memory, but for the life of me I cannot remember what this is from. I did pick up a 64' Dodge in Texas for a buddy, but the car was originally red and still was under the hood. This tag is green and looks very original. Also there is no reason I would have removed his tag.  So I am asking for your help. I have tried to find out for myself what this goes to without any luck. I am hoping one of you more experienced tag guys can help me out here..
Here goes:
     END
H51 J52 L31 N23 R11 V5X
GF3  U     26 B51 C12 F11
GF3. L1F6 CF7 520 21119
K44 D34 VL41 G2R 314722
I did the pencil rub with a piece of paper to make sure I was reading it as best possible and I think it's all correct.
Thanks for any and all help as usual. :cheers:
Steve
Steve P.
Holiday, Florida
Steve, using the handy VIN decoder on my site provided by StockMopar....
Body Type:   V  =  Plymouth Valiant / Duster
Price Class:   L  =  Low
Body Type:   41  =  4 Door Sedan
Engine:   G  =  318 150HP(net) or 155HP(net) 1-2BBL 8 CYL
Year:   2  =  1972
Sequence Number: 314722  =  214722nd Vehical Built
tAG......
Code     Description
E44   318-2 Barrel
D34   TorqueFlite Automatic Transmission
VL41
G2
R31472   Sequence Number 'R31472'
GF3
Paint Code: Medium Green Metallic
L1F6
Trim Grade/Style/Color
L = Low
1 = Cloth and Vinyl Bench
F6 = Green
GF7   Upper Door Frame: Dark Green Metallic
520   Date Built: 5 / 20 / NaN
21119   Order Number: 21119
GF3   Roof Type OR Color:  Medium Green Metallic
U   Built to Specifications for USA Order
26   26 in. Radiator
B51   Power Assisted Brakes
C12   Shoulder Belts
F11   50 Amp
H51   Single Air /w Heater
J52   Inside Hood Release
L31   Hood / Fender Mount Turn Signal
N23   Electronic Ignition Standard only 4bb Engine
R11   Music Master Radio AM
V5X   Black - Mouldings - Protective Insert Body Side
END   End of Codes
Steve P.
WOW!!!!  Thanks Chris.. That was FAST!!!!!!!!!!!!!!
I still have no idea how I ended up with this tag. I have never owned this car. At least I don't remember ever having one like it.. Maybe it was a car I stripped many years ago in NY. I crushed alllllllot of iron back then..  :brickwall:
Again, thank you..
:cheers:  Steve
PS. Still searching for the f-tag for my 65' ...    :brickwall: :brickwall: :brickwall:
Steve P.
Holiday, Florida
