Holley Carb
Started by GRN66CHRGR, April 25, 2008, 12:29:11 PM
GRN66CHRGR
I purchased a 66 charger about a year ago with a 383. Its been updated with an edelbrock intake & Holley 750 double feed. When I purchased this it had a very bad hesitation & after much review, rebuilding the carb, timing, etc. I found 2 plugs fowling on the headers. I did get it running very respectable & sounds good. One problem is I cannot get the secondarys to kick in? I beleive it to be in the linkage but do not have the info to adjust this. If you run the throttle linkage manuallly the secondarys do not move! :brickwall: :brickwall: :brickwall: :brickwall: Any help would be appreciated!
Is this a vacuum secondary carb or a double pumper ?
gordo1968charger
 :popcrn: :popcrn: :popcrn:
sounds like my car!!
68 charger+4 kids=2 jobs
GRN66CHRGR
Thanks for the reply Ron, its a double feed & not a double pumper, I think the secondaries are manual as I do not see any vacuum to them. When you manually run the throttle they do open but I do not know how to set up the linkage & do not want to damage anything...thoughts? :brickwall:
GRN66,
In your first post you state that the secondaries are not opening but in your last post you state that they are in fact opening.....this is a bit confusing  :P
A double pumper carb has mechancal secondaries...this is what you have.  ;)
The 750 cfm holley is available as a double pumper (mechanical secondaries) and as a single pumper (vacuum secondaries)
Check your throttle linkage & cable to make sure it is properly adjusted and that when you floor the gas pedal the secondaries are opening fully. There is also a special mopar specific throttle adapter that needs to be installed when mounting a holley carb on a Chrysler engine.
The part number is 20-7 :
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY%2D20%2D7&N=700+115&autoview=sku
