Seal head gakets?
Started by AKcharger, April 07, 2008, 12:34:55 AM
AKcharger
Guys I feel stupid to ask this but I'm about to put my new 440source aluminium heads on and the '72 Dodge manual says to "apply sealent" and position gasket...I don't remember any sealent with my 383 I put together 5 years ago. So If it does get sealent where is it supposed to be applied?
AK
there is somekind of "sealant" used down here on metalic gaskets, specially on intakes. Is kinda a rubber cement. Down here ppl calls GOMA LACA. I have used to pans gaskets too.
Bill, if you are using the head gaskets in the 440 source kit which are a composite (ROL brand) style there is no need for sealant. Only the steel shim head gaskets require a spray on sealant (copper coat).
AKcharger
Ah!  gotcha///must be a '70's thing
Thanks... now I just need to find all the head bolts, I'm missing a few things after our house move in Jan
Quote from: AKcharger on April 07, 2008, 02:25:27 AM
Bill, if you need some head bolts lemme know....i've got some spares kicking around here.  ;)
Quote from: MorePwr on April 07, 2008, 06:25:02 AM
Ron, to clarify. is this an Aluminum head requirement, or do you copper coat iron heads also?
Aaron
Aaron, doesn't matter what the head material is....if it's a steel shim (Non composite) gasket....it gets copper-coated.  :paintingpink:
I've always used Copper-Cote on all head gaskets, even composite, but the ROL gaskets say not to; they are sticky when removed from the package so they already have some sort of sealer applied.
AKcharger
Copy
Thanks for the bolt offer Ron, I should be fine...plus I still owe you for that washer!
Fast_68_440
Quote from: firefighter3931 on April 07, 2008, 02:02:07 AM
I have a similar question.  I am using the head gaskets from the mopar gasket kit out of the jegs catalog (part number 312-P3690175 ).  I believe they are composite gaskets (haven't received the shipment yet to check).  I am reading the 68 service manual and it says to "coat new gaskets with suitable sealer, MoPar Number 1057794 or equivalent."  Will I have to use a sealer on these or can I just put them on and bolt down the head?
Quote from: Fast_68_440 on April 16, 2008, 12:12:46 PM
Fast68,
The FSM refers to a stock factory head gasket which was in fact a steel shim head gasket. Those do need some coppercoat on both sides and are not a composite style gasket like the Felpro's or ROL's.
All of the gasket kits i've seen have comp with the composite head gaskets.  :yesnod:
