module grounding
Started by doitmopar, January 30, 2008, 06:40:08 PM
doitmopar
:brickwall: Does the ing module get it's ground through the mounting screw on the firewall,or is there suppose to be a separate ground in the wiring harness?I'm not getting a neg at the coil.Thanks
Charger-Bodie
Quote from: doitmopar on January 30, 2008, 06:40:08 PM
:brickwall:Does the ing module get it's ground through the mounting screw on the firewall,or is there suppose to be a separate ground in the wiring harness?I'm not getting a neg at the coil.Thanks
The mounting surface must be clean of paint etc to get a proper ground of the ignition box.
Sixt8Chrgr
Quote from: 1hot68 on January 30, 2008, 06:42:47 PM
Does this hold true with the voltage regulator? I can't get a charge from the alternator and the alt. is new, VR is new, wiring harness is new. I am stumped. I get a no charger situation at my ammeter. Pull the positive cable off of the battery the car dies. I actually have two VR's that are new and the situation is the same with them. Perhaps they are both bad? I have 12 volts on the ignition side of the VR and 2.4 on the field side. Any ideas?
Thanks,
Charger-Bodie
Quote from: Sixt8Chrgr on January 30, 2008, 09:29:48 PM
Thanks,
yes, same applies  :yesnod:
