rear end build--advice
Started by Brian in GA, July 30, 2007, 12:34:52 PM
Brian in GA
Hey guys.  I am in need of your expertise.  I have the rear end housing, 8 3/4 axles, and a center chunk with 3.23 limited slip.  I need to know what bearings I'll need, and how to put this together correctly.  I know this may be intensive, but I don't have much experience doing this and want to learn to do it myself.   :shruggy:
If you need to know, it came from and is going back into a 68 r/t charger with a close-to-stock 440 and 727.  I'm trying to get it on wheels, and the rear center chunk and axles had been scavenged from this car long ago.  I have recently purchased replacements, and I need an idea of what else I'm missing, and how to do it.
Thanks in advance for the schooling.   I'll be waiting.   :popcrn:
What casting number is the rearend?  It should be a 742 with a clutch type limited slip but after this number of years, who knows for sure.
Help with ID and bearing/seal numvbers can be found on this page:
http://www.autohobbydigest.com/8_75.html
The factory service manual is your best guide for properly assembling all the pieces.
kamkuda
New axle seals is always a good idea
