My attempt at an OEM lower control arm
Started by hemi68charger, June 21, 2007, 08:28:01 PM
hemi68charger
Hey gang...
This is MY attempt to duplicate the original cosmoline look of the lower control arms for my '68 Hemi Charger R/T.. Think it's hokey? I even tried to duplicate the run marks of the original cosmoline dipping process of the control arm.. Had to make sure the runs go down the length of the arm, not from top to bottom in it's installed position like I've seen some.. What they forget is the arm was dipped and dried hanging from the lower ball joint attach point....
The color looks more gold than it really is because of the flash..
I'm not trying to create a trailer queen, just something of which I can get a car to look something like the Pro's would do, but I did it in my backyard and garage... I'll be getting all the suspension paint markings as well for whatever I can come up with in my research...  It's a challenge, but oh so much fun !!!
Houston Mopar Club Connection
71_Charger_R/T
Looks good! what did you use to get that look?
hemi68charger
Quote from: 71_Charger_R/T on June 21, 2007, 08:56:59 PM
Thanks guys.. pretty much Krylon Battery Protector.. Then I'll go behind it with a Krylon Matte Finish..
PocketThunder
Yep looks good Troy (the other Troy) :icon_smile_big:    :2thumbs:
"Liberalism is a disease that attacks one's ability to understand logic. Extreme manifestations include the willingness to continue down a path of self destruction, based solely on a delusional belief in a failed ideology."
hemigeno
If there was a smilie to give a long low whistle of appreciation, I could put it up here.  Nice work.
hemi68charger
Krylon Battery Protector is available, hit and miss, at auto parts stores.. I ordered mine online from a company that specializes in Krylon paints.. I'll check it out and post a reply... I believe it was R.S.Hughes Co Inc. Do a good search on them and then search on the site for Krylon Battery Protector.
The Matte Finish toned down the gloss which I like better.. It should clean/wipe up easily with that applied... We'll see when she dries. I'll go out there and spray some Simple Green or something on it and see how it wipes...
I decided to get rid of the black torsion bar anchors and redo them in "cosmoline"...
Big Lebowski
Cool dude, looks good. I used Cosmoline in a rattle can. It took many many coats then some sunshine drying time. The pics are in my '70 resto pics thread at pg.2
     http://www.dodgecharger.com/forum/index.php/topic,8760.30.html
"Let me explain something to you, um i am not Mr. Lebowski, you're Mr. Lebowski. I'm the dude, so that's what you call me. That or his dudeness, or duder, or you know, el duderino if you're not into the whole brevity thing."
hemi68charger
Quote from: Big Lebowski on June 23, 2007, 03:00:48 PM
Hey Big..
The coats on that look like the spray cosmoline I bought.. It was REAL thin and would have taken alot of spraying and drying to get a good coat.. Dayclona also sells it, but wanted something sooner..........
Big Lebowski
Quote from: hemi68charger on June 24, 2007, 07:04:52 PM
Hey Big..
  Yep, it took many coats, and around 4 days of coating it then setting it in the sun. The rattlecan cosmoline wasn't fun, & I hope it doesn't eat the silver paint on the arms. That would suck.
