73' Charger door weather stripping clips
Started by BMOTOXSTAR, June 12, 2007, 08:12:38 AM
BMOTOXSTAR
Where can you purchase the clips that are used on the door weather stripping? Does Year One have them?   :scratchchin:
73' Dodge Rallye Charger 400/4BBL
06' Dodge Ram Quad Cab 4X4 HEMI
15' Dodge Dart 2.7 SXT
clips are only to outer quarters... rest are selftaping screws...
clips came attached already to fuzzies
YO fuzzies REALLY S**CS... my own experience
BMOTOXSTAR
Nacho,
   I mean the clips that keep the rubber stripping on the inner part of the door, the rubber piece that seals from the underneath of the door on the inside. :scratchchin:
oh ok, no window felts. You mean door weatherstrips around. They come with clips already too
GTrestorations sells a combo with upper seals ;) I got from them. They also sells vertical quarter seals... not the best but works. They are all steele rubber made
Bob
Do you mean the plastic ones that can be inserted in the rubber and them pushed into the door?
BMOTOXSTAR
Bob
I went to a body shop and bought a bunch when I did mine. They usually have a good assortment.
BMOTOXSTAR
Bob
