Silver Paint
Started by 71mopar383, May 26, 2007, 09:47:24 PM
69fourspd
One thing I would add with the metallic - Once you spray the metallic base, do not sand it.  If you sand metallic you will get light and dark spots.  Just mist the metallic on very dry, and lay down clear over this.  You can then wet sand the clear for a great finish.  Either way if you go with metallic (single or double stage), you will mess up the metallic sanding it out.  Go with base/clear.
