68 Charger Door Glass - Missing plastic "button" to hold the glass to the frame
Started by Corellian Corvette, May 07, 2007, 05:15:00 PM
Corellian Corvette
Did a search and didn't see anything on this. Putting my door glass back in and I noticed that there is a little blue plastic "button" that holds the frame to the glass. On one side it's still there, but it's broken on the other one.
Are these parts reproduced? I would like to remove the frames from the glass and clean them, but not sure how to assemble them w/o the button.
Thoughts or suggestions? What are other people doing?
mikepmcs
Corellian Corvette
I'm not sure if that will work or not. Specifically, this is the part that was removed. You may be able to see the little tabs are broken.
Dennis K
Yes, that's the same part. The new ones are white, and the originals were blue. The new one is the uninstalled version, the one in your pic has the center plunger pushed in. The way they go in is to put the 4 little "fingers" throught the hole in the glass, then push the center plunger in to hold it all together.
