Pitting in clearcoat
Started by triple_green, May 07, 2007, 01:28:01 PM
triple_green
I have some pitting in the clear. Paint is 8 years old. The problem is that dirt stays in the pitting even after normal washing.
Can I sand down the clear (not thru) and shot another coat over it?
Thanks!
3X
68 Charger 383 HP grandma car (the orignal 3X)
Silver R/T
has the car been wet sanded after it was painted? Sounds like dirt got into clear when it was painted, you'll have to wet sand it then buff it
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
triple_green
yes it was wetsanded after it was painted. I think there was some bubbling in the clear and it was worn away into pitts.
3X
Silver R/T
2001 Ram 2500 CTD
Charger-Bodie
Quote from: Silver R/T on May 07, 2007, 09:55:57 PM
more like fisheyes
or like solvent pops! or like moisture! whats up with you silver ? you give the guy an idiotic response and then you treat HIM like an idiot geez get real! by the way it could possible BE fisheyes also but i dont think he asked what is was just what he could do to remody it!! :brickwall: :RantExplode: :RantExplode: :brickwall:
by the way 3x green if the surface imperfections dont go all the way to the basecoat you could probably sand it down to the bottom of them and reclear it but chances are it will break thru somewhere and you need to spray more base on it then clear....good luck keep us posted
Silver R/T
chill out. Guy doesnt know what the problem is, and I was trying to figure it out. You have to know what problem is before you start fixing it.
2001 Ram 2500 CTD
Charger-Bodie
Quote from: Silver R/T on May 07, 2007, 11:22:10 PM
if you were trying to figure out the problem you have asked questions not blirted out crap :shortbus:
bill440rt
Ok, ladies...   :angel:
Triple, can you get some close-up pics of this paint condition so we can see what you're talking about? If it started as small bubbles, then burst causing pits, it could very well be moisture as 1hot68 suggested. I'm not sure if it would be solvent pop, especially on a paint job that's 8 years old. Solvent pop usually occurs right away, whereas moisture can take some time to show up before it rears it's ugly head.
dongar69
What ever you do, don't sand on the dirt or you'll grind it into the underlying layers.
Clean it out best as possible first. Try using a pressure washer. Then clay bar. Then
maybe a mild solvent such as wax and grease remover or adhesive remover to remove
as much dirt as you can.
triple_green
