I'm using the 318 - Opinions?
Started by RogerDodger, January 27, 2007, 01:21:22 PM
RogerDodger
My budget is telling me to wait on a big block and use the 318 that came out of my 74. It ran quite well when I took it out 18 months ago. I believe it has about 110,000 miles and is the original motor. It did smoke when first starting it up so I'm thinking new valve seals. No big deal. Also I noticed the freeze plugs need to be replaced. I was doing a compression test and I have 165 and 160 on the first two cylinders and then my compression tester went bad. I don't know what the specs are for a 74 318 but I would guess that is good if they are all consistant. I guess I'll try to get a new compression tester and confirm. I don't want to put a lot of money into this motor because my goal in a couple of years would be a big block, tranny and rear end. Thats just more than I can do right now. Any thoughts guys? Am I crazy to use this motor with 110,000 miles on it? Is there anything else I should be considering?  :icon_smile_question:
Charger-Bodie
if the compression is fairly close on all 8 and its good id run with it for now just :icon_smile_big: replace the frost plugs gaskets ect and run it
ChargerSG
Looking for 383 Magnum #0B196875 and 0B115166
69bronzeT5
I had a 318 that had 100 something k's on it. I got rid of it and bought an old 68 4 dr Chrysler Newport for $500 and took the 383 out of it along with tons of other parts.
Daytona R/T SE
Timing chain and gear,freeze plugs,valve guide seals,oil pan and valve cover gaskets,clean it up real good,paint it and drop it in. Should be able to do all of this for $100 bucks or so....
RogerDodger
Quote from: 69bronzeT5 on January 27, 2007, 08:57:16 PM
I have been looking for an old Chrysler. I would like to find one locally. Anyway that will be a couple of years down the road. For now I'll put the 318 in and start logging some miles this summer (I hope). :drive:
RogerDodger
Quote from: Daytona R/T SE on January 28, 2007, 12:05:37 AM
Your thinking like I am. I went last night and picked up all the above and a water pump. $150. :thumbs:
Daytona R/T SE
Quote from: RogerDodger on January 28, 2007, 07:32:36 AM
:thumbs: 318's are literally bullet proof. A well tuned one will give decent power and economy. Should last you a long time.
318 is a GREAT engine... I know is not a 440, but is really great. You can add a nice 340 intake and will get some nice extra power.
RogerDodger
Should I replace the rear main seal while I'm doing all this? I already have the pan off. How much more work is it to change the rear seal? I did one a long time ago on a Chevy. I think I took off the rear main and pushed it out with a small wood block. Actually I may have had to loosen all the mains if I remeber right. I hate to miss something at this point. I have enough oil spots on the driveway from my children. :icon_smile_tongue:
I f you have the oil pan off it is no big deal to do the rear seal , I would check a few brgs too , #2 main & 5/6 rod , you may have to loosen all the mains & lift the crank slightly to change the seal
RogerDodger
I got the rear seal changed. It was pretty easy. When I check the bearings am I just doing a visual check or do I need to get some plastigauge and torque them back on? The rear main looked good when I had it off.
Polygon
QuoteTiming chain and gear,freeze plugs,valve guide seals,oil pan and valve cover gaskets,clean it up real good,paint it and drop it in. Should be able to do all of this for $100 bucks or so....
Thats' it. At 130,000 my chain went poof and bent some valves.I would put in BRONZE valve guides, never gave me any problems....
www.lostinspaceforum.com
If you like the old TV show, Lost In Space, check out my page
RogerDodger
Quote from: Chryco Psycho on February 04, 2007, 02:19:17 PM
Here is a picture of #2 main and #5 & #6 rod bearings. I'm not sure what to look for. The rod bearings show some discoloration.
If these bearings are showing wear then it looks like I should be doing a total rebuild.
The70RT
They look kinda scarry. I would plasti-guage them. It looks like they are into the second layer.....kind hard to tell from the size of the pics. Did you get a new oil pump and clean out the sump?
RogerDodger
It is hard to see in the picture. Some spots are new looking while others look stained. 70RT - You mentioned layers. I was wondering if it had worn through a surface layer or if it was just stained.
I did clean out the sump. No new oil pump.
The70RT
I never seen a stained bearing. Now a scorched or oil starved bearing may change colors. Plasi-gage them to be sure.
