linkage set up
Started by darkside, August 15, 2006, 10:00:16 AM
darkside
thinking of a  demon and rpm intake on my 383.Is this  this linkage set up the one i need. magnum hp sells it  383 performer kit  ARE - 44.also will it work with my factory kickdown linkage?
andyf
It will work with your factory linkage IF your factory linkage looks like the one in the picture.  It won't work with other styles of kickdown linkage.
That kit is designed to work with a factory carb so if you put a Demon on there you'll need the Demon throttle extension (MagnumHP should have those in stock) and you'll need the long OEM throttle stud.  You might be able to take the long stud out of your existing carb if you have a factory setup on the car or you can probably still buy them from the dealer.
