Tach + Clock is not Tic Toc Tach?
Started by Corellian Corvette, July 06, 2006, 01:47:17 PM
Corellian Corvette
Another random question.
My guage has a Tach + Clock with a singe lead off that back.
When I see pictures of hte Tic Toc Tach, it's not the same thing.
Mt Tach/Clock is totally dead (tried it on another car an nothing), so I'm thinking it would be cheaper/easier to replace with a new repro Tic Toc Tach.
Is that a direct replacement? Is there wiring that needs to be changed or can I just use the old lead + a new harness?
THanks!
JimShine
It sounds like you have a plain clock. Which does yours look like?  Top pic is a plain clock, bottom is Tic Toc Tach.
Corellian Corvette
Isn't that outer part a tach?  ??? and the inner part is a clock?
I have the upper thing. :)
So how hard to upgrade to the tic-toc-tach?
JimShine
The outer ring is the seconds hand. Note how it goes through clock increments.
There is an additional wire that runs out through the firewall for the Tach. I am not sure what the harness is composed of. I am sure someone here can detail when you need to change and add.
terrible one
I think the main thing about changing to a tic-toc-tac is the money!
Corellian Corvette
Ah, now it all makes sence. I thought it was just a 6K rpm tach!!
Well, it doesn't work and I want a tach. So I just ordered one along with the harness. Bye bye, money!
RDR-838
