valvetrain noise
Started by 7273chargerguy, May 31, 2006, 03:40:37 PM
7273chargerguy
1973 318 brand new everything bottom and top end,drivers side valve cover off.started car and a clacking sound still. using a wooden handle i press down on the pushrod side and the valve side of each rocker arm but sound does not stop.pushrods turn while engine is running. i soaked the lifters in lucas oil for about ten minutes. is that long enough? push rods turn easily by hand and are not loose.heads are off a 1980's 318 while the rocker shaft/arm assembly is original to the 73.heads were just rebuilt by reputable machine shop.so what do you think, lifter problem,maybe a bad cam lobe? HELP!!! ???
"yours it not to question why,yours is just to do or die."
N. ever A. gain V. olunteer Y. ourself
7273chargerguy
RD
i will be down tomorrow! we can check her out then buddy! :D :D
7273chargerguy
doctorpimp
7273chargerguy
