ok there was a purple charger in here that a guy put a cam in...he posted a vid
Started by Harper, December 24, 2017, 09:54:25 PM
Harper
ok so there was a guy with a purple charger (69?) that posted on here with a vid he had just put on youtube, the car had a great sound!!! anyone have a link?
thanks in advance
1968 Dodge Charger
1969 Dodge Charger (GL Clone)
1951 F1 Ford 302 EFI, Automatic
1965 F100 Ford Straight 6, 3 speed on column (all original)
Harper
1968 Dodge Charger
darbgnik
This is my only hesitation in installing fuel injection, supposedly it really cleans up the lumpy cam idle, which is probably one of my favorite things about my car.........  :shruggy:
Brad
Quote from: darbgnik on December 24, 2017, 11:04:25 PM
Cam grind dictates idle characteristics. Not source of injection be it carb or electronic.
Harper
1968 Dodge Charger
darbgnik
Quote from: c00nhunterjoe on December 24, 2017, 11:13:08 PM
I'm hoping you're right. All I have to go by is an article I read on how fuel injection somehow compensates and smoothes out the standing waves inside the intake...... or something like that??.
Here's hoping it doesn't.  :cheers:
Brad
darbgnik
Brad
igozumn
Friend of mine put a Fitech on his 69 Nova with a 454.  Another buddy swears his sounds different.  I don't recall enough to comment about his setup.
My Charger sounds just a little different, I suppose.  But depending on the "tune" or "out of tune" of the carb that was on a particular car before, sure.  It could make a difference.  After all, you could be changing the air/fuel ratio a fair amount and that will make the little explosions in the cylinder act different.  No different than plucking a guitar string differently.  Same "pitch" but different timbre.
A man walks into a psychiatrist's office wearing nothing but underpants made from saran wrap.  The psychiatrist says, "Well....I can clearly see your nuts...."
The only way i could see the idle changing going from a carb to throttle body injection such as holley or fi tech, is if the carb wa soooo messed up that your idle was loaded up. Otherwise, its not going to change. A carb is a mechanical fuel leak. A throttle body injection is an electric fuel leak. Period.
Harper
1968 Dodge Charger
69wannabe
Quote from: c00nhunterjoe on December 26, 2017, 08:35:03 AM
You right Joe, I did notice a slightly different idle when I had the fi-tech on my car but it still had a good lope to it. The holley carb does have a little better sound to me at idle but there is not a day and night difference. More than likely the throttle body was leaner at idle so it did sound slightly different and the carb is going to run richer at idle with a healthy cam.
Multiport injection with mass air meter- f cam is similar specs to the mp509 cam
https://youtu.be/nQjdyM1CQWg
My old 383 with a custom cam similar to the mp509
https://youtu.be/9gpncCxfZ44
Granted 1 is a 302 and the other a 383 with different bores and strokes. And 1 is hydraulic flat tappet and the other is roller, the overlap characteristics are similar enough to show that fuel injection will not make it have a smooth idle.
darbgnik
Quote from: c00nhunterjoe on December 27, 2017, 03:54:33 PM
That's encouraging for sure. I'm also curious how low the EFI will let me set the idle......  :scratchchin:
Brad
