Are my float levels too high? - Carb flooding
Started by rollo1504, June 19, 2017, 01:06:42 PM
rollo1504
Will do it! I know that it is very important to keep fuel lines away from heat sources!
It was just for a short testing... Will reroute the fuel lines anyway very soon... but thank you for the concern.
Roland
BSB67
11.68 @ 120.2 mph
Great work Roland....the project turned out very well. You're getting a handle on this Mopar thing  :icon_smile_big:
The slight hesitation going wide open is normal for a vacuum secondary carb....nothing to worry about. I would recommend setting the idle at 750-800 in gear (drive) which should help with the stalling out issue.  ;)
Vaccum readings are fine....the idle vacuum might increase with an increase in idle speed  :yesnod:
Nice improvement on the looks and performance  :2thumbs:
rollo1504
Hey!
Ok Ron...!
Thank you all for helping me!
This service is priceless to me...  :icon_smile_cool: :icon_smile_cool: :icon_smile_cool: :2thumbs: :2thumbs: :2thumbs:
Will come back for sure later with other normal and dumb questions....
Next steps:
- Fine tuning via reading and hopefully understanding spark plugs
- Uprade fuel lines to 3/8"
- Install mech fuel pump edelbrock 1723
- Install 3/8" fuel sending unit
- Install front and rear shocks
Will see what problem will come up next....
Thaaaaank you guys!
Regards from AUSTRIA
