Head Porting
Started by randy73, May 09, 2017, 09:03:40 AM
randy73
Does anyone know of a good head porter for Eddy heads?
Want to get mine ported before I put the engine back together.
Challenger340
Some porting, and re-do the Seat Angles/Valve Grinding.
IMO,
you would be very surprised just how much re-doing the Valves/Seats/Throats, installing a REAL Valve Job (compared to as supplied by Eddy), picks up the Head Flow all by itself, with very little actual port work ?
Jim Laroy, (Heyoldguy) on here.
Duane Porter, (PRH) on here.
What is your geographical location ?
Only wimps wear Bowties !
randy73
Was thinking of a mild porting and valve job.
I live in Florida now.
Quote from: randy73 on May 09, 2017, 10:50:26 AM
On the east coast I would recommend Dwayne Porter.....he's done hundreds of those. Everything from basic prep to full on porting and in between.  :2thumbs:
Porter Racing Heads :  802-951-1955
randy73
Thanks Ron, I will give him a call.
Quote from: randy73 on May 10, 2017, 08:28:03 AM
Dwayne did my E-heads on the old 446 pump gas build. Stage 1 port with PRH valve job. That combo made 535hp/540 tq with 10.2:1 compression, solid cam, street dominator single plane intake, 850DP & 17/8in headers.
That combo ran 11.60's at 4100 lbs  :2thumbs:
randy73
I just called him, he was straight up and honest and so will be sending him my heads.  Thanks everyone for your help.
Excellent....you'll be able to sleep well knowing that these heads are ready to bolt on and go !  :2thumbs:
