Hood insulation pad
Started by Voss, July 16, 2016, 06:54:55 AM
Voss
Thinking about replacing my hood insulation pad. I see a few different options out there. What is the most correct one if you want an original look? I found this on eBay:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=320997915941
I also found this fiber molded one:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=131857045111
A lot more costly though...
Any thoughts?
BLK 68 R/T
hemi-hampton
Did your car originally come with one? LEON.
Voss
Quote from: hemi-hampton on July 16, 2016, 08:02:15 PM
No clue really...  :shruggy: This car had a hard life before I bought it. There is a pad in there now, but it's not anyway near correct. Was this pad an option? I assumed that all cars had it but I might be wrong?
hemi-hampton
As far as I know you only got the under hood pad if you opted for the J55 Option which was extra Undercoating at extra cost. LEON.
Voss
Quote from: hemi-hampton on July 25, 2016, 02:38:02 AM
Ah, right... Unfortunately I don't have the build sheet, guess I would need that to know for sure if my car came with the J55 option. I will anyway get a correct pad installed since it saves the hood a bit from all the heat. I wonder what the thinking was behind that J55 option. Undercoating + hood pad? I don't directly see the need for a hood pad if I ordered extra undercoating?  :popcrn:
hemi-hampton
The reasoning for it was they were both considered part of the sound deadening. LEON.
P.S. Should be on your fender tag if factory.
