need help with numbers stamped on dist pad
Started by troy.70R/T, August 28, 2015, 05:33:34 PM
troy.70R/T
I was wondering if anyone could decode what the numbers on a 383 engine that I have that I am getting ready to use in my charger.
it is a 65 casting
A383
2     12
    R
That is kind of what it looks like on the pad.
69CoronetRT
A= 1965 model year
2 12 = assembled February 12th, 1965.
70 sublime
troy.70R/T
Thanks guys. Wow real exciting motor.  :'( O well it will get the car on the road.
that's the same motor I'm running in the Daytona.....65 2bbl engine, Weiand 4bbl intake, dual exhaust, I can cruise at 100mph all day long, runs on regular fuel, and best gas mileage I have got with it is 24.5 mpg.....
troy.70R/T
Thats good to know. Is it a stock cam? Do you know the cam specs? what gear ratio are you running.
50 yrs later, i doubt it has its origonal components in it. I wouldnt sweat what is stamped on it.
Quote from: troy.70R/T on August 30, 2015, 07:22:54 AM
cam is the six pac cam from a 440...and my gears are 2.76...pistons are still dog dish 2bbl low compression ones
troy.70R/T
thanks A383wing. I will find out how mine runs in a few weeks. I hope.
