Bucket seat latch return spring?
Started by bull, April 19, 2012, 11:21:45 PM
bull
One of my two seat latch return springs was broken and I'm trying to collect all the parts I need to finish them up. Is there a source for these things I'm not thinking of? I've checked a bunch of the usual outlets but no luck yet. About the only thing I might be able to do otherwise is get a piece of spring steel wire and make one. Watcha got?
bull
That's what I figured. :'( Funny thing is I tried helping another member out with the same problem more than a year ago. Now I'm in the same boat: http://www.dodgecharger.com/forum/index.php/topic,77852.0.html Looks like it's time to take a trip to the wrecking yard.
FWIW, the part number is 2888582. Collector's Auto Supply stocks the left side (2888583) but not the right, and the right side is the one I need. :brickwall:
bull
For the past week and a half I've been searching for this part; and nobody has it... literally. Not even Bubba in the Alabama wrecking yards has one for $50 this time. So I started looking at other torsion springs and thinking "modify" was the only way to go. Today marks my fourth attempt at modifying a spring to work on the passenger side seat and it finally worked. I found a couple of old springs, snapped one in half and spent about 45 minutes tweaking it into shape. It fits correctly and does what it's supposed to do. :2thumbs:
E5 Charger
Great job! It not only works, but looks enough like the original that no one would notice unless you told them.
440
Can you get piano wire and bend it up? I suppose now that you have one that works there is no need to continue.
When can we start placing orders ? :lol:
bull
Quote from: 440 on April 30, 2012, 04:11:11 AM
Funny you say that. Just last night I modified a second passenger side part (below) from what was left of the spring above and it turned out even better. This stuff doesn't seem quite as hard as the Ebay Toro lawnmower spring I used on the third attempt. That one was snapping left and right.
I was thinking yesterday that a car radio antenna might work too. I wish I had some sort of jig for this because my hands are getting sore.
69rtse4spd
You can buy spring winding kits, we have one here at work. Clamp in a vise & bend away, we use to make most of our own springs for work. Look in McMaster & Carr, if you got an origanal spring you do not need to use right away, send to me & I can see what I can do for you, if you want.
bull
Quote from: 69rtse4spd on May 01, 2012, 11:18:45 PM
Do you bend them by hand usually when using these kits?
36 Dodge Brothers
Lucky you bull. I just took my seats apart to install the new foams and Legendary covers and when I took the hardware off so that I could stick the frames in my sandblast cabinet I found both sides broke. I did a google search for the springs and it lead me to your post so I guess I am out of luck. It's no big deal the seats have been that way for who knows how many years and I never noticed it before, actually now that I know I am bothered by it! :'(
Marco
Regards,
Marco
68 Charger R/T
36 Dodge D2
lasvegas69charg
hey bull.  I'm in the same situation. My driver side is missing and I  can not locate one. I would be happy to pay you if you can reproduce me one. Let me know...thanks.
69 dodge charger 383/727/3.55 (my dad is the original owner-matching number) stroked to a 496😉
FLG
bull
Quote from: FLG on August 18, 2012, 02:08:43 AM
Oh boy Curtis, calendars and springs now  ;D
The calendars got much easier since I started doing them through Shutterly. :2thumbs:
Quote from: lasvegas69charg on August 18, 2012, 12:02:50 AM
Still thinking about the best way to approach this. There are some jigs you can buy but money is pretty tight right now. But when something happens I let you know.
lasvegas69charg
bull
Quote from: lasvegas69charg on September 12, 2012, 09:08:05 AM
ok. Just let me know.
I started making one by hand last night with some new material. Looks like it will turn out pretty good.
bull
Well, I decided there was enough of a need to look into reproducing these things so I had a bunch of them made out of stress-relieved 302 stainless steel. Megaparts now sells them: http://www.megapartsusa.com/proddetail.asp?prod=MP%2DSHS6869
