Does hood insulation deaden sound? Or is it just heat?
Started by XH29N0G, January 03, 2015, 05:46:25 PM
XH29N0G
Does installing hood insulation change the sound levels coming from under the hood in a noticeable way, or does it just affect heat.
Or maybe it protects us.
Charger-Bodie
Yes they do dead on sound some. If you wanted you could go even further and stick some sound deadner on and then the hood pad.
johnnycharger
Just make sure your air cleaner won't rub against it. :brickwall:
charger Downunder
Quote from: johnnycharger on January 05, 2015, 08:11:29 AM
Yep my six pack air cleaner rubbed big time so i removed it. I had one of those molded hood pads and it was like a scotchbrite pad sanding through the air cleaner top.
[/quote]
XH29N0G
I had read something like that before, but not like scotchbright.  Yikes   :scared:  I'll be careful because I really don't want that issue.
Morals
It will only affect directional sound. Kinda like putting a bed sheet over a tv or labtop, it will muffle the higher frequency sounds.  Sound deadner does ruffly the same thing, it is meant to stop vibrations but will stop some directional sound.
Quote from: charger Downunder on January 05, 2015, 06:01:42 PM
DAMHIK  :brickwall:
