1977 440 motorhome engine ????
Started by alkyburner, August 08, 2014, 11:49:48 PM
alkyburner
I went and looked at a 1977 motorhome with a 440 with a 727 transmission earlier it sounded good...anyways they are hooking it up to the tow truck and suppose to have it here around noon tomorrow I guess I want to ask and make sure this thing will work in my 73 charger. I know I will have to get motor mounts and change rear end and torsion bars as it was a sb car....but want to make sure it will fit... im also assuming I will maybe need a different oil pan for it if it does work and was wanting to know what years I can get a car oil pan from thanks
alkyburner
im new to this stuff and just want to make sure...I have tried googling and seeing mixed reviews about having to change the tail shaft and stuff.. so can someone maybe tell me a way of knowing. maybe a ruff measurement from motor/trans mounting to end of tail shaft to know if it will work in the car thanks...
The motorhome trans will not work in the Charger.  The 440 will if you have a big block k member.
alkyburner
thank's for the info I will call first thing in the morning and tell them not to bring it out....so I will also have to change the k member then to..i thought I could buy aftermarket motor mounts to bolt a bb in the sb car??
I think Shumaker makes a set of motor mounts to do the swap.
alkyburner
ok so 440 and the motor mounts is a go with the k member that's in the car now... and no on the transmission in the motorhome because of the tail shaft being short and having a drum type shaft. so I need a bb 727 with a long tail shaft that uses a slip yoke type driveshaft right...from what I have read and seen
Bob
The transmission in my 74 is out of a motor home. Allot of medium size m/homes used the same 727.
hawkeye
You will also need the long shaft that goes thru the tranny and several small parts.  I just had one swapped over and I just used a junk one to rob parts off of.  All v8 k members will work-- the 6's were different.
Quote from: hawkeye on August 09, 2014, 07:09:40 AM
untill 72 yes, not since 73. 73 and lates changed also between SB and BB, hence the mount ADAPTORS ( more than just a mount ) from Schumacher
http://www.engine-swaps.com/Pages/Show%20Pricing/73UP-Show.html
On pic you can see how the offset is noticeable on one of the mounts
ACUDANUT
Another reason to go 71/72 Charger. Right Nacho.  :icon_smile_big:
don duick
any plans to rebuild it ? hope it goes well if using as is. Had same motor in my charger was an ok cruiser not a great performer and used a lot of gas.
Quote from: ACUDANUT on August 09, 2014, 09:36:52 AM
:smilielol:
or maybe a 2nd gen
:smilielol:
alkyburner
said it had been rebuilt already has new heads on it and been sitting about 10 years. sounds good though...
ACUDANUT
I would pass on the Motorhome engine.
alkyburner
reasons why to pass on the motorhome engine???? just curious. also the guy has a 727 with the long tail shaft but has some kind of parking brake thing on the end of it can this transmission work. he said something about just taking it off.
don duick
now you have it and you know it is a good runner, you might as well give it a try. I would.
ODZKing
The 74-74 suspension is different from 71-72 if you are going to stay with factory.
Because of that the oil pan is different.
The oil pan is 3614970 (400 & 440). It will have a "971" embossed in it.
http://www.440source.com/oilpans.htm
RallyeMike
Quotereasons why to pass on the motorhome engine?Huh just curious. also the guy has a 727 with the long tail shaft but has some kind of parking brake thing on the end of it can this transmission work. he said something about just taking it off.
Motor home engine are not as desired by people but they are fine engines and cheap alternatives. You can usually find low-miles runners for $3-500 around here. The only real hurdles are that they are difficult to put a manual trans behind because of the external balancing and they have low compression which makes less power. Of course, the low compression is good for today's low octane gas. A 1978 440 motorhome engine with stock crank, rods, and pistons in one my chargers is still fun to drive, churns the tires, and has taken it to 140mph (in a legal, sanctioned, event)
In some early 60's cars there is a parking brake assembly that attaches to the end of the 727 tailshaft. It brakes on the drive shaft. I'm pretty sure some of the bosses on the case are different than what you'll need to get various stock shifters hooked up. Craigslist usually turns up lots of 727 around here. You might try that first.
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
as far I kno USUALLY motorhome and some trucks engines got bigger water jackets on heads for better cooling there... right ?
alkyburner
ok thanks' for the help and responses I will probably go with it then
alkyburner
came across a 1966 383 with a 727 thinking about going and looking at it. anything I need to be looking for thanks. I also found a 73 440 with 727 trans that came out of a state trooper car.
