opinions
Started by dukeboy_318, April 24, 2014, 09:14:34 PM
dukeboy_318
Anyone ever have try the edlebrock torker 2 plus cam shaft number 5092? I just picked one up cheap, 25 bucks brand new still in box from a friend of mine. What's the opinion on this? is this a roller cam? can't find on edelbrock's site, two other sites list it, one says hydraulic roller, other says hydraulic flat tappet, same part number?
specs found here
http://www.performancedepot.com/ART/...6/5092Inst.pdf
CAMSHAFT: Torker-Plus Hydraulic
CATALOG #5092
ENGINE: Chrysler 413-440 c.i.d. V8
RPM RANGE: 1500-6500
CAUTION: Do not use dual valve springs.
Use only recommended Edelbrock Sure Seat Valve
Springs #5792.
Use stock ratio rocker arms only.
Duration at .006" Lift: Intake 292Þ Exhaust 292Þ
Duration at .050" Lift: Intake 230Þ Exhaust 230Þ
Lift at cam: Intake .320" Exhaust .320"
Lift at valve: Intake .480" Exhaust .480"
Timing at .050 Lift:
Open Close
Intake 7Þ BTDC 43Þ ABDC
Exhaust 45Þ BBDC 5Þ ATDC
• CAUTION: Use Edelbrock Performer-Plus Timing Chain
and Steel Gear Set #7804. Do not use late model timing chain
and gear sets that are designed for emission-controlled
engines. These timing sets are machined in a retarded position
and are not recommended for this camshaft installation.
Edelbrock Timing Sets feature three keyways for specified
timing selection.
1978 Dodge Power Wagon W200 4x4- 408 stroker/4spd
1974 Dodge Dart Swinger. 440 project in the works.
Is that the Edelbrock cam?  I think thats a flat tappet if it is.
BSB67
Hmmmm.  Kinda seems like no one is wanting to respond.  Did not look it up, I'm assuming it is a flat tappet.
It has slow moving ramps, kinda old school.  It will have more bark than bite on the performance side.  It should be very easy on parts (springs, lifters, rockers, pushrods).  If you are looking for a high performance /rumpity  type idle, but not looking for every bit of power corresponding to the sound, it will be a fine cam.
11.68 @ 120.2 mph
That cam is very similar to the Comp 280 Magnum grind. It'll want a 2500 stall and 3.91 gears for best performance.   :yesnod:
