RMS install
Started by chargedup68, January 09, 2014, 11:27:14 PM
chargedup68
Front Reilly Motorsports suspension is in, looks pretty good, now for the rear and to find some wheels to fit the 12.19 inch brakes. :scratchchin:
68 Charger, 608/683 505 cu in. Muscle Motors Stroker, MASS Flo EFI. Reilly Motorsports Alterkation/Street Lynx suspension, Wilwood brakes, Strange Dana 60 4.11 gears, Tremec TKO 600
69chargerboy
Wow, Looks great! I was debating buying one of those... :scratchchin:
My MoPar Family:
1968 Chrysler 300
1968 Coronet 440 4-Dr
1968 Coronet 440
1969 Charger
1973 Charger SE
1988 Dodge Custom 150 Pickup
bill440rt
chargedup68
Just had their 6 piston 12.9s installed.  They went in easy on the RMS suspension and somehow my old 15 inch wheels cleared the brakes...barely!
2Luke2
Looks great! May I ask where you got it from and around how much the whole setup was? We are redoing our suspension and with everything we are replacing and the parts we are using we are pretty close to 3,000 including all the steering components. It might be worth it to us to just throw in the bit extra and get a whole new front end.
Sublime/Sixpack
It does look nice. Let us know how well it works out for you.
Supercharged Riot
nice to know your 15 inch wheels still fit.
I have been debating about whether i should get that brake setup as well.
Thanks for sharing!
Do post more my friend.
Did you get the whole set from RMS?
chargedup68
I ended up going with the whole setup on RMS after reading about some of the other setups on this forum and am glad I went this route.  The lynx rear setup is next along with the Strange Dana 60 that I ordered from Central parts racing.  I will end up running an 18 inch wheel once I can find a style that I like enough to pay the money for.
HPP
The Nascar boys use 12.19x1.25 rotors in the cup races with their 15" wheels. That's 'bout as big as you can get in a 15" wheel.
chargedup68
TKO 600 installed after some tunnel fabrication.  Strange Dana 60 4 link tabs installed and painted ready for install.
Wookie316
I had to go to a 17" wheel with my RMS kit. 15" touched the tie rod end unless I put a 1" wheel spacer in. What BS is your rim and what are you running? I was trying to fit a 15x7" rally wheel and it was a no go.
1971 Plum Crazy SupeBee. 400 bored and stroked to 511, 727 spinning a Dana 4.30
Wookie316
Here is a shot with the 1" spacer. Without it would have hit.
chargedup68
It is really close to the wheel weights and I will be moving up to 17 or 18 inch wheels anyway.  I have 3.75 in from the lug mounting surface to the edge of the wheel.
myk
Quote from: chargedup68 on March 21, 2014, 11:47:41 PM
Glad to hear it; I wouldn't see the point of setting up a trick suspension and then sticking with smaller rims...
