Ch4b and coil
Started by billssuperbird, January 09, 2014, 05:24:48 PM
billssuperbird
I an putting a ch4b intake on my sb clone. How do I keep the coil in the stock spot.  :brickwall:
BSB67
11.68 @ 120.2 mph
billssuperbird
On my ch4b what carb gasket should I use.
Quote from: billssuperbird on January 10, 2014, 07:03:54 AM
I like the thick carb gaskets....they insulate and keep the fuel cooler with less chance of fuel boiling/vapor lock  :yesnod:
http://www.summitracing.com/int/parts/edl-9265/overview/
billssuperbird
bill440rt
My coil is mounted like this on my CH4B.  :cheers:
