Unused wire on relay
Started by Dino, October 05, 2013, 04:12:11 PM
I'm installing the 5 pin Bosch type relays for the headlights and am not sure what to do with the 87a terminal wire.  I know it's not used on a 69 so what do I do with it?  Tape it or remove it entirely?  Will the 87a terminal have power coming to it at all?
Mopar Nut
87a terminal not used on headlight system
Let me restate the issue.  I wasn't clear.
I did not run the wiring to the relay individually.  I bought two sets that each came with a relay and a pre wired socket.  The 87a terminal on the socket has a foot long 14 AWG wire and I'm not sure if it ever has power to it or not.  If not then I will just tape it into the loom but if it does then obviously I need a better idea.  Once I have wrapped all the wiring I plan on using rtv sealer in the bottom of the socket and lots of dielectric grease between connections to keep it sealed as best as possible.
that wire is not used...either remove it, or just tape it off in loom
MaximRecoil
It is easy to remove it from the plug. Just slide something small and thin in there from the front to depress the locking tab on the brass terminal, and the wire and terminal will slide right out. I removed that wire from both of my relay plugs.
