440 idle...
Started by Jderek, April 19, 2012, 01:30:47 PM
Jderek
Why is it my Charger idles at 900rpm at cold start but on the street at stop once warmed the idle won't fall below 1300rpm?  I have a Holley 830cfm.
'68 Charger, 511" stroker(609hp,688tq), 4speed, 4.56's, 33x21.5 Mickey Thompson ET's.
BOSSHEMI
does the carb have electric choke?
just your avg "car guy"
RallyeMike
Not sure how your carb is configured (does it have a choke?), but in general first check the balance betweeen the throttle idle screw and the fast idle cam screw:
Screw in the fast idle cam screw a couple of turns. This should increase your cold idle speed.
Back the throttle idle screw out several turns.
Start the car and let it idle on the fast idle cam screw.
When it warms up kick it off the fast idle cam and make sure that the throttle is resting on the throttle idle screw
(at this point it might die if the throttle idle is very low).
Restart and set the throttle idle to whatever rpm you please.
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
Jderek
Quote from: BOSSHEMI on April 19, 2012, 01:55:34 PM
It doesn't have a choke.
Jderek
Quote from: RallyeMike on April 19, 2012, 01:57:09 PM
Thanks much for the help...will try this...am looking over the Holley 830 manual to see which screw is which ( newbie) lol.
