360 motor mounts
Started by nrt69, March 26, 2011, 11:02:29 PM
nrt69
does anyone have a part number for 360 motor mounts...going in a 69 Charger?
Kern Dog
Since the 360 was never installed in a 2nd gen Charger, you wont find a part number from Ma Mopar. Schumacher has non factory type mounts that will work though. You may be able to finagle something with some 318 mounts and spacers.
66-72 B-body and 70-74 E-body use the same *style* mounts and are interchangeable. The 318 was available in 68-70 Chargers and the 318/340/360 all came in Cudas/Challengers. So, even though a 360 never came in a 69 Charger, correct factory mounts do exist. The 340 and 360 use the same mount brackets. The 318 driver's side bracket works but the passenger side is slightly skinnier (but will work with a "spacer") to take up the space on the end. No need for aftermarket mounts BUT the 340/360 brackets can be tough to find (parts stores will give you the 318 version these days).
Here's an informative thread about the subject on Moparts:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=3735907&Main=3733538
