Headlight problem
Started by John G, August 01, 2010, 10:49:00 AM
John G
Good Day. Maybe someone has come across this problem. Headlights don't go on but will when you put on the high beams. Thanks for the help
John G
mikepmcs
is there a chance that both headlights might actually be burnt out(ie: low beam filament)
mikepmcs
it appears on this diagram that Chris has on his site http://www.1969chargerregistry.com/pictures/ftendlighting.jpg
L4B 16V goes back to the driver side light and ties in with L4A 16V and then goes back to pin 4 of the disconnect and then on to pin X of the bulkhead.
If it's not the simple things like the fuses or lights burnt, we could start here to see of the connection is bad on the driver's side headlight and then follow it back if need be to the discon.
Topher
Either both bulbs burnt as mentioned or the dimmer switch is bad.
Topher
67 Charger 383-4spd "the Dawg"
www.headlightmotorman.com
John G
Thanks guys, didn't think that both lights could be burnt out. I will check it out.
