firm feel fast ratio pitman arms
Started by Hemidog, September 23, 2008, 11:34:36 AM
Hemidog
Thinking of buying a firm feel stage II box, and a fast ratio pitman arms.
I know the long idler arm wont fit, I already had to grind a little bit on the stock one to clear the TTI headers.
Does anyone know if the fast ratio pitman arm fits on a big block b-body with TTI headers? B Engine.
The TTI website says no, but I just wanted to check, would like all the improved steering I can get.
NMike
if the idler arm doesn't ft, you cannot use the the longer ptiman arm. they must be the same length or you screw up you steering angles.
Hemidog
Quote from: NMike on September 26, 2008, 10:29:57 PM
The T/A Challenger and AAR Cuda had a long pitman arm and short idler.
From Firm Feel website:
"long pitman/short idler = OK ackerman thru right hand sweep and OK ackerman up to about 20 degrees left. From ~20 degrees on out , the Ackerman gets exaggerated to ~10-12 degrees. We don't think this really adds up to very much in your overall performance driving picture, because 20 degrees is a pretty tight turn , more like a parking maneuver than anything else. But.... why not get it as good as you can get it .Conclusion; If you can ..., use the long idler."
