440 block
Started by yellocharge68, June 20, 2007, 10:06:54 PM
yellocharge68
i JUST WON A 440 BLOCK/CRANK WITH SEIZED PISTONS......
According to the numbers posted can any of you old timers or charger aficionados tell what this stuff means???
casting #?? 2536430-8
  cast date 4-5-67
id on the D440 IS 10  10  2 C AND IS REPORTED TO BE MALTESE CROSS????
Any info is greatly appreciated!!!!
by the way the ebay bid item is #230140428452  not sure if you can pull it up after it has been sold.....???
Sunfire Yellow 1968 Dodge Charger 383/727 auto-console
supserdave
Nice score, the crank is probably worth more than what you payed for it.
I beleive the cross meant the crank is .010 undersized on the main bearings. Not a big deal you can turn them down to .030 and still find bearings easily.
As for the numbers, its a 68 non-hp 440, probably from a C body car if I was to guess.
StockMan
I was told that maltese cross can also mean the casting has higher nickel content.
