oil priming
Started by chargerman68, January 08, 2008, 07:36:02 PM
mally69
The rocker's would make a clattering type sound if the holes in the shaft are turned wrong, but the loud clank doesnt sound very good.  Step back for a while, you will get it fixed and or find out what your trouble is. It takes time for the most part..
chargerman68
Quote from: Steve P. on January 10, 2008, 11:32:14 PM
I agree with these guys. Time to take a step back. Crack open the book on building your motor. Learn what it takes and take it step by step from there..
The loud clank does not sound good.  I think we should hear this story from the beginning. BUT,,, first tell me, is this the same motor that you were having trouble getting started a few months ago or have you changed the motor or had it rebuilt?  This is somewhat confusing..
same motor got it from the shop that ripped me off.was i dont know any history on it...
Steve P.
So you have run this motor before, right??  Did it have oil pressure then??
Steve P.
Holiday, Florida
chargerman68
all fixed no grease in the oil pump.repacked it and it ran and had pressure....thanks for the help..... :2thumbs: :2thumbs:
Steve P.
Very good. BUT,,,, what about the CLUNK??
Steve P.
Holiday, Florida
chargerman68
nothing yet maybe it was a socket or something that fell.. :shruggy:
Steve P.
Ok, but it IS holding GOOD oil pressure??  No noises??  No ticking??
Steve P.
Holiday, Florida
chargerman68
holding good and idling :cheers:
Steve P.
Very good.  Have you repaired your brakes yet??
Steve P.
Holiday, Florida
chargerman68
yep she is already after i tighten down everything and fix some small leaks...she will be attending the mopars at the strip this year for sure :2thumbs:
BRS
Good to hear your up and running. :2thumbs:
Steve P.
Very good. We will see you there....   :cheers:
Steve P.
Holiday, Florida
chargerman68
