68 console
Started by 68 CHARGER R/T, August 19, 2006, 12:17:18 AM
68 CHARGER R/T
just wondering if it is still possible to get the bolts that hold on the door to the console. thanks
8WHEELER
Not sure what you mean, the console lid has studs coming out of it molded into the lid.
Then you use nuts to attach it to the spring hinge, then you use screws into the plastic housing.
Dan
68 CHARGER R/T
yes the studs are they still available anywhere
68 CHARGER R/T
sorry actually mine has something like a cone shaped nut
B5 Charger
I got a full set brand new at Ace Hardware.  I believe they are called acorn nuts.  You can find them in the fastener section of most hardware stores.
68 CHARGER R/T
thanks guys for the help
dkn1997
I was sick of my door "popping" off with those stupid cone nuts.  I ran a tap over the studs and used regular nuts.  I know, not factory, but it works perfect and does not stick up anymore.
RECHRGED
JimShine
DKN, I did the same thing. It too about 5 minutes and I wont ever have to touch them again.
