multiple engine stamps
Started by Rudderguy, September 03, 2017, 11:47:35 PM
Rudderguy
From a 68 rt.
Is it normal to have multiple stamps on the data pad?
Can anyone help decode all of this?
Does it look as if there is a "P" faintly stamped in?
Could this be tampered with?
Cheers
Rudderguy
Rudder Guy
6bblgt
not normal but it is seen
what's the VIN stamped on it back by the oil sending unit?
Rudderguy
I am in the process of getting the VIN from the rear of the engine.  Will post when I get it.
What does the numbers mean as far as you can dechier it?
there looks to be a number stamped diagonally above the 440??
HP?
the 22 at the end of the bottom line?
Thx
Rudder Guy
Moparsaver
I'm seeing an original hp stamp under the 22 on the bottom line..I think  :shruggy:
6bblgt
PT440S 2429 2307
PT = Trenton, MI engine assembly plant
440 = cu.in.
S = special (HP)
2429 = engine assembly date Friday March 22, 1968
2307 = engine unit serial number
D440 47 B
3 3 22 3 23 HP 222 AA
lots of stamps on the top pad  :shruggy: bored worker, line stopped, last job 3/22 & first job 3/23
after Friday lunch break & stamped 3 23, sh!t its the 22nd & added a bunch of "2"s (all of the above??)
D = 1968 model year
440 = cu.in.
47 = ??
B = ??
3
3 22 = Friday 3/22/68
3 23 = Saturday 3/23/68
HP = High Performance
222 = ??
AA = ??
Quote from: Rudderguy on September 03, 2017, 11:47:35 PM
I was told that the numbers were stamped with a pneumatic gun and, if the operator didn't hold the gun tightly, the gun would jump up/down and leave numerous impressions.  :shruggy:
Dans 68
Quote from: John_Kunkel on September 04, 2017, 01:35:04 PM
Great bit of knowledge! Thanks, John.  :thumbs:
Dan
