New motor at the drag strip
Started by c00nhunterjoe, August 13, 2017, 08:52:07 PM
Finally got out to test. Lazy launch so i wouldnt rip the shackles off the frame rails. Hope the pictures work. Correction factor of 1.0703 for the weather via my weather station readings, brings the corrected number to 10.26 at 133. Im happy with it for now. I was in the right lane, bumped in too deep, thus the red light.
Laowho
bakerhillpins
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
Hmm. Not sure what to do with the videos. I dont have the copies of them to upload to youtube. Will have to work on that.
cdr
 awesome stuff   :2thumbs: :coolgleamA:   ,  cant see the videos  though  ,
lukedukem
Quote from: c00nhunterjoe on August 14, 2017, 08:26:47 PM
Links uploaded finally.
https://youtu.be/ob5ESA6P9F4
https://youtu.be/wsQhqrPZg4c
Lol, love the guy filming it and his reaction.  :2thumbs:
Car sounds real good. Real strong.
Luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
Lol, that was my brother filming. He hasnt seen the car since the old motor.
BDF
morepower
1968 Dodge Charger 496 Sublime Green 3.91 torqueflite. Built to drive. Best ET 11.73 at 117
2010 SRT Dodge Challenger 6.1 Hemi Orange 5 speed automatic. Daily Driver. Best ET 13.4 at 105
Quote from: morepower on August 16, 2017, 07:06:33 PM
whats the build specs?
Engine- Stock stroke 440. 60 over. 12.5:1 pistons. Indy 440-1 heads, no port work. .750 lift, 320 adv solid roller crane cam. Tti 2 1/8 step race headers into 18" 3.5" collectors. 850 holley hp on top a custom modified tm7 intake welded up to max wedge opening. Aeromotive street pump with 1/2 line to feed it.
Trans- 727 with all the hd upgrades, no light weight parts, rev manual vb with lba. 8" select converter all wrapped in a kevlar blanket.
Dana 60, 35 spline axles, full spool and 4.88s turning m/t slicks. 30x9x15 stock suspension.
