ram transmission codes
Started by flyinlow, June 03, 2016, 05:27:52 PM
flyinlow
 My 2004 ram 4x4 hemi , 130k. miles   Occasionally slow to engage drive after back up. 3-4 seconds  :shruggy: It has been this way for years.
Recently got a check engine ,
PO 700   Trans control system
                              PO 731  Gear 1 in correct ratio
                              Po 876 Fluid pressure sensor switch D Range/performance
Any Ideas? I erased the codes and will drive some more.
Kern Dog
Last month my 265,000 mile 2wd Ram 1500 lost 1st, 4th and 5th. It still had 2nd, 3rd and reverse. It displayed a code but I don't recall the number. I had to pull the trans pan and valve body then replace the solenoid pack. All is well again.
