Plastic windage tray
Started by fizz, May 16, 2016, 05:27:08 PM
fizz
Repaired a rear main seal leak this weekend and replaced steel windage tray with a plastic one I got from Mancini. Has integral raised rubber gasket which seems better than sandwiching the windage tray between 2 standard gaskets. Seems like a good deal. Doesn't leak anyway.
Chargerguy74
They seem like a great idea. The next time my pan comes off I'm adding one of these. I'll probably have to adjust my oil pump pickup a bit.
WANTED: NOS or excellent condition 72-74 4 speed shifter boot for bench or centre armrest car, part number 3467755. It's a rubber boot that looks like it's sewn up leather.
WANTED: My original 440 blocks. Serial # 2A188182 and 3A100002
birdsandbees
You'll need an entire different pick up tube assembly. The windage tray one has a big bend in it, the standard 383/440 pick up doesn't.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
Chargerguy74
I imagine my milodon pickup for my 7 quart pan may work, but I don't recall that big of a bend in it. Hmm...
Challenger340
Are we talking about the Magnum Gaskets Composite Fiber Windage Trays seen here on Page 6 ?
http://www.magnumgaskets.com/pdf/Performance-Catalog.pdf
I've used them on all Pan/Pickup combinations from stock 3/8" Pickup and Pans to both 3/8" & 1/2" Pickups with HEMI 6 Quarts right up to 7 Quart deep sumps.... both std and Stroker Trays.....
and,
I've never encountered a fit issue on any ?
Nice Piece, about $30 U.S.
Only wimps wear Bowties !
fizz
Yes. that one. I didn't have a fit problem either, just replaced the metal one.
