O ring on steering pump?
Started by chargd72, May 02, 2016, 11:33:19 PM
chargd72
Is there supposed to be an o ring on the pressure side of the power steering pump? I thought it was just a compression fitting but it's leaking when fully tightened.
Depends on the pump, Saginaw pump has an inverted flare but the Mopar pump uses an O ring.
chargd72
Ok.  Mine is a Saginaw and brand new so I need to inspect further.  Thanks for the reply.
