just tore apart a 383
Started by rt green, March 05, 2016, 10:16:41 PM
rt green
 so to tell me that i have something [engle cam] in my part stash that'll work?  man, i'd never thought i'd see the day that'd happen. sure that cam is not to much? FWIW i tore this thing down and it had a nylon upper timing gear. not much wear.  blast from the past.
third string oil changer
rt green
Quote from: c00nhunterjoe on March 13, 2016, 06:08:44 PM
:iagree: that will make quite the fun ride at 9.5:1.
Another option if it were mine and you are running 3.91s or 4.10s would be up the compression and go with more cam since its a stick car. The steel shim gasket can get you the needed compression on the 383 to run a steeper cam like the crower 282 or equivalent cam in the low 500 lift and 240's @ .050. If you have 3.55s or less, then go with the 1st cam suggested, even with the 4 speed.
***edit**** seeing the post about having the engle cam on hand- that cam should work well in this engine. I would say no less then a 3.55 gear.
you talking steath heads or 906?
Your 906s. You should sit down and plug all of your figures into a dynamic compression ratio calculator. That is the main problem that comes into play when people overcam an engine. Experiment with cam choices and you will see the effects they have on your dynamic compression and why cam choice vs static compression is so critical. My goal on iron open chamber heads like yours is a dynamic of 8.0 to 8.5:1 to run 93 octane.
  Here is a basic and simple one that will give you the idea. The intake closing should be on your cam card. I dont knkw what it is on the engle cam.
http://www.wallaceracing.com/dynamic-cr.php
Challenger340
The L2293 Pistons for the 383 Engines were somewhere around 10 CC's "NET" if memory serves me ? NOT the mentioned 12 CC's !
in other words....
the 18CC Dome was designed to compensate for the .020" Deck Clrc(4.6 CC) and the 4 Cc "trough" valve relief, and STILL provide -10CC Dome Compression increase.
The 12 CC dome volume number was the L2295 offering for the 440 Engines, intended to act like a zero deck Flat-Top in a 440(9.7 to 10.2 static C.R. depending upon open chamber casting volume)
Nonetheless,
the L2293 383 Dome Piston was considerably higher Dome than the L2295 440 piston, and good for over 10:1 static C.R in a 383 with 88 CC heads.
Only wimps wear Bowties !
rt green
at Challenger340's insistance, i measured dome with a ring compressor. i leveled it, put the piston down .500.  it took 101.5cc of antifreeze. i figured 11 cc dome.   using summit's compression calculator came up with 9.24 to one.
using the Wallace Racing dynamic calculator  i came up with
dynamic 8.10 to 1        intake opens  8   closes42
static 9.24 to 1        exhaust opens 52 closes 6
volume pressure index 170
effective stroke 3.04in
dynamic cranking pressure 161.56 psi
Engle k 58/60
valve lift       running duration  valve lash        gross cam lift           duration at .050     lobe centers
in 515           276                     hyd                in 343                        230                     110
ex 536          285                     hyd                ex 357                        238
BSB67
Quote from: rt green on March 19, 2016, 06:09:33 PM
Engle k 58/60
Hmmm.
How did you measure the 0.050" down, and how did you measure the volume.. Precision matters.
11.68 @ 120.2 mph
rt green
im sorry, it  was .500 down. old style band type ring compressor with piston and rod in vise.  took a hunk of plastic and measured .500 long and cut. was a bitch to get level. did the proper grease seal on rings and plexi glass.  saw no leakage past rings. came up with 101.5cc. 4.80 x .50=118   118[rounded off]  - 101.5 =16.5.   hmmmm. maybe i should ck my math.   i'm trying
rt green
looks like .075 head gaskets, or take 5cc off of domes
I checked my old notes. I had measured the 2293s at 1.911 compression distance. In a stock 383 block that should set them about .020 in the hole. The dome and valve relief measurements i have near what challaneger340 posted earlier. That said, based on your 90cc head measurement, i reccomend Running a blue felpro gasket at .041 netting a decent quench distance even though the open chamber lacks it, and a cam with 74-78° intake closing (think purple 509 size). Will run on 93 and be a rocket with the 4 speed and 3.91s.
rt green
thank you. i thought they quit making the 509.
They still make it, and lots of others with similar grinds. To use those pistons and pump gas the ivc is critcal and a bigger cam is the key to get the dynamic compression to pump gas levels.
rt green
i think maybe you should own these pistons. pm me if interested
BSB67
If you told us what your goal and budget is, I've forgotten.  If you like working on your car and if you don't mind a possible partial redo, you are in a pretty good place for achieving some really good performance, but with some risk of having to get back into it.  I get it though, everyone is different.  Today, folks don't seem to mind spending 10 hr/week talking about their cars and motors and performance, but the thought of actually working on the car for 10 hours (i.e. cam or head swap) is distasteful.
If your budget already allows for new pistons, the budget for new heads will not be more than new pistons, all said and done.  So consider this.  Slightly modify the piston dome on the spark plug side to pull that corner back away from the plug/head.  Consult someone you trust to show/tell you how to do this.  It will do two things, 1) reduce slightly the dome volume, and 2) provide clearance if you go to an an aluminum head.  Put a 0.050" to 0.055" head gasket on, and use a medium sized cam with a wider LSA.  The cost to do this is nothing.
So you put it back together, and it pings.  If it is not too bad there are about a half dozen items you can do to help that, especially in a stick car.  If these don't work, buy the 88 cc Eddy heads and put them on.  This will solve that problem.
Worst case, you will spend no more on the motor (heads verses pistons), and it will probably run a lot stronger.   :Twocents:
11.68 @ 120.2 mph
rt green
my plans for this car is just street cruise with a little punch. drive to work, enjoy the car. i'm not out to murder imports or anything, but would like to have some fun. i took this thing apart and found the high tops. everything else bearings, ring ridge, rockers, pushrods ect, look Very nice shape, and the inside is spotless. i just got the car, so i'm still jacked about getting it going. my budget right now is lower that anyone elses that has even clicked on this site, but i have to have a plan.  last time i didnt have a plan and it just snowballed. i was buying stuff, changing my mind, buying other stuff, no theres something better, buying more stuff ect.      next thing i know, its 10 yrs later, and still looking at a car that isnt together.  i'm just trying to work with what i have. if i cant, i'll have to sit back and save cash. i do have a stock MP replacement cam brand new, but i thought those pistons would be too much for that.
BSB67
Okay.  Maybe a bigger picture question.  Was the car running when you bought it, and if not, besides getting the motor together, what needs to be done to get the car driving?
11.68 @ 120.2 mph
rt green
it needs everything. its blown apart. why did i start on the engine you ask? i tore into it to see what i had. everything is bagged and tagged.  no, did not run when i got it. but i figured the engine had to be done up anyways. then i could plan rear gears, exhaust and everything else.
BSB67
If you want to get this thing on the road and money is tight, maybe start assembling the rest of the car first.  Who know what $$$ black hole you could stumble into.  This kind of a situation (car apart) can nickel and dime you to death.
Put the motor aside, but keep thinking about what you want in the car, and when you get close to the point to where your ready for the motor, then you'll know what you want (at that time) and a sense of the $$ you have available.
Almost every time a guy starts with the motor first, if considerable time passes, it is not the motor he wants when it is time to put it into the car.   :Twocents:
11.68 @ 120.2 mph
rt green
i think i'll take that advice. thanks to all of you who were trying to help.
Thats really good advice! I will add, build your car on paper. Almost like writing a report. Start with an outline, title- goal, then each category, engine, suspension, brakes. Then list all the parts you think you want to use. Now you can look at the whole picture and see what will work together or not, then adjust your goal or parts without wasting money.
rt green
thanks to all who were trying to help me with my 383. before i  slid it under the bench, i put the head back on with the old gasket. got the spark plug hole straight up and level. [top dead center with a dial indicator, little vasoline to seal before]   cc'd it. 73cc's.    =11.9 to one   FWIW     thanks again,   bruce
Slap a monster cam in it and a set of gears and have a nasty old school street/strip car. Excellent score. I am jealous.
