just finished headliner
Started by tiki, August 26, 2015, 01:28:23 PM
tiki
vinyl top and headliner is done... :drool5:
tiki
heres the new top getting close... :drool5:
tiki
Lots of hp just over 600
tiki
Date born 1969 date died 1982 resurrected 2015...When i bought the car from Vegas the inspection sticker was still on the windshield 1982
cincyboy
cbrestorations
looks nice, what heads are on it? its much harder to get 600hp than it sounds especially with just a dual plane intake manifold
Cncguy
tiki
TTI headers and exhaust and looks great underneath with all the chrome :cheers:
keepat
Very nice! Headliner looks awesome. Who's aluminum radiator are you using?
Pat
cbrestorations
Quote from: tiki on August 26, 2015, 02:05:21 PM
no what heads (engine)
tiki
oh sorry, they are edelbrock heads i bought the stroker kit (500)compression is off the charts,had it running on the stand and it sounded really throaty if that's
a word...
tiki
pic is not working----- I installed the alumim angle iron to mount the dixi horn i looked and cant find what radiator that i used, i know it can handle the 600 horses,under the dixi horn you can see the trans cooler,running back to the tranny w/an fittings very cool...
tiki
this is it
tiki
keepat im using KILLER HD 1967 - 1974 Mopar BIG BLOCK 26" Aluminum Radiator 26" CORE
keepat
Quote from: tiki on August 27, 2015, 06:33:07 AM
Tanks you!
Pat
tiki
sorry pat i was going to use that one but i didnt,mines got grooves on the side like the original ill look again
:popcrn:
tiki
http://classicfordradiator.com           66-69 Charger Roadrunner "B" Body 26" wide Aluminum radiator (click on mopar section)
tiki
Thank-you it takes so much time and effort to get these mopars the way you want them...Im getting close front/rear glass both doors and all fluids,wheels and tires,I have to run the electric fuel pump wire to the alternator,and a few misc wires,adjust,adjust and adjust and i cant wait to hear it with the exhaust on,then we take it for a test drive... :2thumbs:
tiki
How many run 2 fuel pumps mech/electrical? or is that a given...
I just run a good mechanical.
tiki
electrical fuel pump connected to the alternator for safety
1974dodgecharger
Quote from: tiki on August 29, 2015, 08:46:19 AM
I thought electrical needs to be below the tank output?
tiki
no it will suck a golf ball through a garden hose,equipped w/check valve,there is a return line from the vapor separator   :2thumbs:
tiki
i just got the vinyl top put on last week, now im trying to locate the hole locations for the rear window trim clips thank you to bill440rt for providing detailed pics  :cheers:
