'69 440 cutting out, help please!
Started by K9COP, May 21, 2015, 10:03:48 PM
K9COP
Quote from: 70 sublime on June 30, 2015, 07:34:46 PM
If you have the PCV hose going in where you do will it not just put the oily air into just one cylinder all the time ?
I think if it was at the front it would get mixed and go evenly every cylinder
Honestly, I don't know  :shruggy: I'm here to learn . So do I swap the large PCV hose from the intake to the large point on the front of the carb, and have the large hose from the brake booster go to the intake? If so, what do I do with the small hose/port that is attached to the carb and the PCV now?
I'm more of an OBDII kind of guy...sorry...
K9
I'd rather push a Charger than drive a Mustang.. which is lucky..
My cars:
'69/70 Charger 440
'03 Range Rover
'05 Audi A8R
'93 Lotus Omega (SOLD)
'97 Jag U Are XK8 (For Sale)
'68 Charger 318 (for sale)
'74ish Charger 400Magnum (sold)
'89 Nissan Skyline GTR (sold)
'92 Jeep Cherokee 9" lift (sold)
95 Crown Victoria Police K9 unit work car! (in the great impound lot in the sky..)
Yeah I'd swap those hoses.  Pcv to the carb, booster to manifold.
birdsandbees
What ^^^ said ! Brake booster goes to the manifold port, PVC to the carb.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
K9COP
Thanks guys. I'll do that. Do I leave the small hose on the intake port 'T'd' to the front of the carb?  Trying my best not to be spoon fed here, but just want to understand...
I'm absolutely NOT doubting anybody here, but trying to understand why.... could the car always have been running rough on one cylinder (rear right) because it was filling with dense, oily air?
K9
My cars:
'69/70 Charger 440
'03 Range Rover
'05 Audi A8R
Ha I didn't even notice the hose going from intake tree to the carb!  Remove it and cap them.
Sure you can definitely have an unbalanced burn.  Check your plugs and find out.   :yesnod:
K9COP
Thank you Sir! I'll take care of the hoses tomorrow, and replace the plugs too. I have a set waiting, but was looking for a solution before I put another set in to get fouled up!
As always Dino, guys, thanks for being generous with your knowledge and time.   :notworthy:
K9
My cars:
'69/70 Charger 440
'03 Range Rover
'05 Audi A8R
BLK 68 R/T
Once you do get the vacuum lines connected correctly, brake booster line to rear intake port, PCV line to front of carb large port, small line on the right front of carb should go to the distributor advance, cap the other one and no tee in the rear line. You will most likely also need to adjust your idle speed and ignition timing as well to compensate for all the changes being made to the vacuum system. Also don't forget to undo the vacuum line to the distributor and plug it when you are setting your timing.
K9COP
Quote from: BLK 68 R/T on July 01, 2015, 12:07:38 AM
Thanks for the information. I think the distributor advance should go on the left (drivers side) port though, as in the diagram I just found online below.... probably should have found this sooner...:
I'll put rubber caps over the tee on the PCV valve and the timed vacuum port on the Carb. Makes me wonder why it was done this way though..... :shruggy:
K9
My cars:
'69/70 Charger 440
'03 Range Rover
'05 Audi A8R
BLK 68 R/T
I had mine hooked up to the right hand side on my 68 GTX and it worked just fine. Never tried the other one though. It also had the mopar electronic ignition dist. installed. Honestly I have no idea what the difference is in the vacuum signal between the 2 ports. maybe someone else will chime in with a more definitive answer on why to use one vs the other.
K9COP
Quote from: BLK 68 R/T on July 01, 2015, 11:58:39 AM
Looking at the diagram above, it seems to be just the difference between 'timed' vacuum and manifold vacuum depending on whether the vehicle is emissions controlled or not...
K9
My cars:
'69/70 Charger 440
'03 Range Rover
'05 Audi A8R
69wannabe
Get a look at the spark plugs and see what they look like. Pic's of them would tell if you are too rich or too lean. I would plug off the vacuum advance on the distributor and run it without it hooked up. Mine has been plugged off for several year's with no issues. Chrysler's and ford's were bad about over advancing and causing it to spark erratically. Need to get your ignition system perfect then your carburetor will usually be easier to work with...
K9COP
Got it. Looking at my car, and the pictures again, and it has a small vacuum hose coming FROM the pcv on the right valve cover to the small right hand vacuum advance port on the carb, the a all hose going between the left (drivers side) vacuum advance port to the distributor..  Now that can't be right! :rotz:
Pulling plugs tomorrow.
K9
My cars:
'69/70 Charger 440
'03 Range Rover
'05 Audi A8R
