OEM. Spade Connectors
Started by J.Bond, July 30, 2014, 06:53:29 AM
J.Bond
Had a small electrical mishap last week. Had the J-2 wire from the ignition switch to the bulkhead connector fry, and now need to replace it. Are the factory or replacement spade connectors with the small tab used to lock the connector to the plastic plug bases easily obtainable?????
James
yes, available... Packard 56 series kind
This is one website, but google and will find a lot of suppliers:
http://terminalsupplyco.com/Store/Default.aspx?CATDRILL=DEL010
mostly sure you'll find them available locally too.
NAPA has them, numbers 725147 and 725145
J.Bond
Nacho; Muchas gracias.....
John; Thank you....
Spade connecters should be in today.
