removing charger emblems?
Started by Stegs, July 07, 2014, 07:04:34 AM
Stegs
Hi guys, wondering what is the easiest way (if there is) to remove the charger "arrow" from the front headlight door and the emblem between the tail lights
my charger was a 383 before, now has a 440, so I want to install the r/t emblems
is there a trick to getting them out? how do I go about getting the headlight door off?
and the one on the back, do you just pop them out?
The one on the back is held on by three speed nuts on the inside of the panel, I forget how the front is held on but it doesn't require the door to come off to change it.
No shame in leaving the arrows on though you know. :Twocents:
Stegs
Quote from: Ghoste on July 07, 2014, 07:46:48 AM
I know that...but I like the look of the r/t....I will keep the old emblems for sure tho...even tho the back one is broke ..
twodko
Pretty sure you'll gave to drill another hoke for the R/T emblem.
UFO
Are we dealing with a '69?
Then the back will require a hole to be filled,three studs on the arrow and only two for the R/T emblem.
Headlight door emblem is easier to get to after taking out a headlight bulb.
Stegs
Quote from: UFO on July 07, 2014, 11:23:41 AM
yes we are dealing with a 69 charger
the front headlight door has the arrow on it....the "charger" decal is on the grill itself...that's staying
the rear emblem is a "charger" with the arrow...held it by 3 prongs
UFO
Front emblem has two phillips head screws holding it on.R/T emblem on frt uses the same holes and screws.
Stegs
Quote from: UFO on July 07, 2014, 01:45:55 PM
thank you...once the emblems get is I will start working on it!
Stegs
how would I go about doing this?
UFO
I don't remember the pattern off hand but I think all three(from the arrow emblem) have to be filled.Then two new ones for the R/T emblem drilled.
A welder is about the best way to go. Bondo or JB weld might work but it's not what I would do.
Stegs
oh really? I didn't know that, I thought the new emblem would fit in the old holes.....hmm....
yea I might not want to do that until I have the car repainted next year....maybe ill just do the r/t on the headlight door for now.....
thanks for the info!
